LG SMART INVERTER WASHING MACHINE NOT SPINNING
Denis4844
Hungary
T1366NEFTF
LG
Less than 1 year
Hello,
I would greatly appreacite if some experts help to identify the solutions to issue on my LG smart inverter Top washer:
The type of inquiry : Product Operation Product/Model No. : Top Loader/T1366NEFTF Washing machine does not spin and it shows error OE. i have checked from manual that this errors cause due to drainage. I have already checked following but coudl not able to suceeded: Checked and remove the debris from hose and filter tray Checked the drain pump. It is working fine since it remove all water prior to drainage Checked the drain motor and it is also seems working fine since its open drain and raise the clutuch prior to spinning. In thw view of above checks, can u please suggest me whatelse to check. Thanks
We have no tech. data information on European models, try a appliance repair forum closer to where you live. UK Whitegoods is one.
