btalberg
- wm2277hw
- LG
- More than 10 years
Our LG Tromm WM2277hw is making a grinding noise when the drum spins (see here). I thought the splines on the drum shaft might be bad, but I've replaced the rotor hub assembly and the grinding persists. I'm now convinced the problem is the motor rotor rubbing against the stator. I believe that's because the drum shaft is coming too far out through the bearing (see here). This makes it so the motor rotor doesn't sit flush and has some play to it.
I took the washer apart down the spider bracket to see if the bracket was deteriorating, but it looks okay to me. And when I spin the drum by hand, it spins smoothly, so I don't think the bearing is the problem.
Any ideas what might be going on? Does my theory that the drum shaft is coming too far through the bearing sound right? And if so, any ideas what the fix is?
Spider bracket and shaft
Shaft poking through hub assembly
