LG washer leaking underneith, in the front
louwho
WM2016CW
LG
I have attached two images of the underside of the washer. Washer1, shows the brown structure at the front (where the door is?), that is right up next to the white plastic drum casing. Where the light is shining on the brown part, you can see a little bit of a black round hole, basically on the same level as the white plastic casing of the drum. The washer2 image is an up close picture of that black hole. While the machine was running, I had the back of the washer off, a hand mirror underneith, and a light on the mirror. During spin cycles primarily, I could see the water leaking from the black hole, onto the drum casing, and then leaking uno the floor. If it was spinning real fast, it would splash all over. So, is this a machine structure problem, a door gasket problem, or what? Can I as a home owner do this, or is this a service call? If this worth fixing or not? Thanks in advance for your help and direction.
