LG washer making rattling noise during the first 5 minutes of the wash cycle, then works fine
smithani
Toronto, Canada
WM2250CW
LG
Washer makes loud rattling/grinding noise every time during the first 5 minutes and after that the noise goes away (see video at
). There are no issues with the tub spinning. i.e. the washer does complete washing the clothes properly as long as the load is light. If the load is heavy then washer does stop in the beginning with "LE" error. I don't hear the noise if i manually spin the tub by hand.
EugeneK
Alberta
Firts of all check harness with multimeter (put probes on each side of the harness and then wiggle harness up and down) from hall sensor to the control board. Sometimes wire brakes where clip holding the harness . If thats ok, then change hall sensor.
