LG Washer WM2250CW De code -not door switch
hsp
Florida
WM2250CW
LG
I have this machine, replaced the door switch. When you start a load it will start and run for 10 minutes and gives the same error. Will not finish a load, any ideas?
Here's the service manual: https://drive.google.com/file/d/1CCxITpTSlAkHOm0OOYZYG7gfVzy_M7vU/view?usp=share_link
Page 21 dE error code=Door Open Error:
• Door not all the way closed.
• Loose electrical connections at Door switch and PWB Assembly.
• The DOOR SWITCH ASSEMBLY is out of order.
Then look on Page 27 DOOR OPEN ERROR and do the flowchart steps it mentions to do.
Here's the door lock/latch switch for your model:
Door Lock EBF49827801
Here's the PCB Assembly for your model, if needed:
Pcb Assembly EBR78263908
