LG Washer WM2277HS - need to change the bearings and seal
tigerpilot
Naples, FL
WM2277HS
LG
I need to change the bearings and seal in this LG washer. Hopefully someone has a procedure to remove them that is mostly successful. LG no longer has a replacement rear outer drum. Maybe a machine shop to pull the bearings? Any suggestions other than the garbage will be greatly appreciated.
Thank, Don
tigerpilot
Naples, FL
Hey Jake:
Do you think I can repair the three shocks (dampers) that got separated during my “skilled” drum removal (383EER3001E)?
Thanks, Don
That I don't know Don, I always just replace the shocks, I've never tried to repair them before.
Unfortunately your shocks are coming up as NLA:
383EER3001E Shock Absorber
BadDNA
Durham NC
If you want a free seal, and it fits your machine, I have a gently-used seal from my old WM0642HW. All I ask is you cover the shipping costs, if it fits your unit.
BadDNA
Durham NC
Good luck with the rebuild. The youtubes I watched when I tackled mine were really helpful.
