LG Washer WT1101CW / Agitator Noise
johnwildes
Chicago, IL
WT1101CW
LG
I've attached this video, and it seems like similar posts here. There's no actual grinding, but a loud belt like rubbing noise when the agitator goes back and forth. Used to be super quiet. Is this covered under the 10Y direct drive engine warranty? This unit is about 7 years old.
Linking here because the video is 90MB https://1drv.ms/v/s!AsRdjew6mux7sfMM1KVn6jb8notbMw?e=O5pP9x
Appreciate the thoughts
Hi, yes I'd first check your pulsator to see if it's starting to strip on the clutch shaft it mounts onto.
Here's the Pulsator Assembly for your model:
AGZ72909711 Pulsator Assembly
If the pulsator is not stripped, then it possibly the clutch is making that noise.
Here's the clutch/bearings assembly for your model:
AEN73131403 Clutch Assembly
Also check the rotor at very bottom of the machine.
Here's the rotor for your model:
Motor Rotor Assembly 4413EA1004D
