- WT1101CW
- LG
- 6-10 years
the customer is complaining that the washer wouldn't drain or spin. I put it into diagnostic mode and both the drain and spin worked. the customer states that they had someone out and that company replaced the clutch motor, the shifter arm assembly and the pressure switch. the drain hose is clear and the drain pump works perfectly when in diagnostic. Does anyone have any suggestions on why the washer won't drain on its own? thanks for the help.
