jgrosky
- WT7200CW
- LG
- 1-5 years
Hoping for some ideas please! .....our washer gets stuck at the spin cycle and won't drain; accompanied by the OE code. I've removed the drain pump to check for obstructions and bench checked it for power. I've checked to make sure the drain hose isn't clogged or kinked; I've even cleaned it out, though there wasn't enough junk in it to be a problem. I thought maybe the main control board was possibly not giving voltage to the drain pump ( I grasped at that only because the wife said the washer controls had locked up on her and/or didn't respond); I replaced the main control board and still have the same issue. Anything else I should check? At my whits end, here.
