LG WM4270HWA - Repeated LE error code
CBE47
Long Beach, Ca
WM4270HWA
LG
I can hear a rough attempt at turning. I would like to fix this on my own. Any advice on a thread to read?
Hi, I couldn't locate the service manual for this model.
But I did locate these 2 threads for similar models with this same LE error code:
Its best to first check wire harness to the hall sensor, located on the stator, to make sure wires did NOT BREAK inside that wire harness . Just ohm test the wires, put your meter probes on each side of the harness and then wiggle harness up and down. Unplug your washer first from the wall outlet.
There is a video of accessing the stator and he shows you how to disconnect the wire harness from the stator hall sensor, then all you do after that is go and disconnect the other end of the wire harness.
Click here for this video of your stator which includes the new hall sensor:
Ok, sounds good. Keep us posted.
