LG WT1201CV OE Code replaced pump still won’t drain
Waynevpearson
Louisville tn
WT1201CV
LG
Hey all I’m getting an OE code. Thought pump was bad so replaced pump. Still getting code. What’s next?
Rick posted the service manual in post #4 here:
Check to see if your getting 110 to 125 Volts AC to it when it should be draining. If your NOT getting 110 to 125 Volts AC to it when it should be draining, then your control board is the culprit.
EBR75857901 Pcb Assembly,main
Ok, then the problem is your control board(Pcb assembly).
You can order it from my link to it in post #2 above.
Ok Wayne, sounds good.
