LG WT4970CW UE cant solve
Tayloorscott
Az
WT4970CW
LG
Top load washer, probably around 4 years old. It has a 413PN... serial so I believe that's with the newer control boards.
I get the UE code during the rinse cycle. Our older son used the speed wash all the time, and I never noticed him getting the error, but on normal and heavy duty washes the problem has gotten worse and worse, and now I cant get a load done.
I replaced the suspension rods, boom, first load with sheets not and a single problem. Was thrilled, but now it's worse than ever. I checked the stator nut on bottom, its tight. Washers balanced. I checked the water level pressure season tube that it's clear, and it is. I did notice the sensor had a rattle inside of it though.
I ran clean tub mode with nothing in the washer and it went through many cycles of of draining during the rinse cycle. I never pay attention to a normal wash, but it seemed like the pump was trying to drain water for a long time after the tub was already empty. Sign it might be the pressure switch?? It didnt through an error though even though it seem to go through many rinse cycles. I got tired of watching and I think it finally threw the UE in spin cycle.
I'm about to check the drain pump and hoses to make sure they're clear but anyone got any ideas? Maybe the water-level pressure switch, or something else related to UE?
Doesnt seem to be making odd noises
Tayloorscott
Az
Yeah, I saw that bulletin. Believe it's for serial numbered machine lower and older than my unit.
I saw that too, but I believe it meant just updating the software on your current control board if the serial number was for yours. Since its not, I would think replacing the control board would fall under the category for the UE error fix, if your serial didn't match for the updating the software on your current control board.
Tayloorscott
Az
I appear to have fixed the issue. For anyone else that may run into it, check that your drum is centered. Mine was level, but I noticed it was a little off center. Measured it and indeed it was about 3/4" off to one side. I picked up some thick 1" washers up at hardware store and cut a slot about the size of the suspension rod with my angle grinder. I inserted enough washers in between the rubber washer and existing washer preinstalled on the rods on the top side of the washing machine. Drum is now centered. I've done 3 loads of mixed sizes and no issues.
Excellent good job.:)
Let us know if you get anymore UE error codes.
Tayloorscott
Az
**UPDATE**
Washer is now on the curb lol
Worked for about a week or so. I played with it some more but just sick of wasting my time and money on it. Not the first issue I had with this LG.
Hopefully I'll have better luck with my new whirlpool.
Yes, your new Whirlpool will be much better.:)
bligh
NJ
For anyone with that UE problem......What's causing the failure is dirt/moist dirt on the large spinning drum on the bottom
of the machine. (forgot the name) This drum has foils to pick up air and direct it into the machine for cooling? Anywho, it also picks up moist dust/dirt from the floor under the washer, this moist dirt gets trapped between the magnets and causes sensor reading errors to be sent to the cpu. LG says to replace the board....I cleaned that drum (and the rest of the mechanical parts and the mach works fine and has for over 1.5 years.
