FIXED LG WT5001CW Spline on new clutch is the wrong size
Gokart83
Savannah Ga
WT5001CW
LG
I ordered a new wash plate a few years ago and it fit fine. I had to replace the clutch assy. recently. Ordered the part and installed. It started the UE code so I figured the splines was stripped again (common problem) When I removed the wash plate, I discovered the spline on the new clutch was much smaller than the old one. I called the part supplier and they don't have a clue. I've looked all over the web and can't find a pic of a large shaft like my old one. Anyone know whats going on? Was there an update and am I better off buying a new wash plate to fit this clutch?
Thanks in advance for your help!
Yes, it looks like they redesigned the washplate to a smaller spline.
Here's the washplate for this model you can order:
Washplate AGZ72909701
Here's the clutch for this model:
Clutch AEN73131403
Gokart83
Savannah Ga
That is the clutch assy I ordered. Do they still make the large spline style or should I just get the newer wash plate? Is the newer wash plate and clutch any better than the old? Thanks for helping me.
No, they no longer make the older clutch spline.
So, yes you'd need to order a new washplate for the new clutch spline.
Yes, the new washplate is better.
Gokart83
Savannah Ga
Thanks!! Thats what I was thinking. I guess if they no longer make it, I have no choice. At least its better.
Yes, I agree.:)
