LGEF3043KFH Control Board / Wiring Harness questions
FrigidaireHelp
NC
LGEF3043KFH
Frigidaire
During troubleshooting of why my Bake feature wasn't working I found some melted wiring on my control board.
IMG_20180630_103757.jpgIMG_20180630_105017.jpgIMG_20180630_105022.jpgIMG_20180630_111158.jpgIMG_20180630_105106.jpgIMG_20180630_105112.jpg
It seems obvious that I need to replace the wiring harness but my first question is given the pictures and extent of damage does it seem that I should replace the control board as well? Ideally I'd like to only replace one or the other if I can get away with it due to cost.
Second question is regarding the harness itself. I found 2 potential harnesses, Part #316580280 and Part #316580474. Which one would be appropriate?
Thanks in advance for your help.
You don't need to replace the wire harness. Just cut the bad wire back and add a new wire end. Cut the burned part of the plastic connector off so the wire will go on terminal. The board looks like it needs to be replaced.
Yes, I agree with Rick.
That control board will need to be replaced as well.
You can order it here: 5304510064
FrigidaireHelp
NC
Thanks for the advice! What is that metal connector on the end of the wire called that I need to cut off & replace?
