- LGHB2867PF2
- Frigidaire
- 6-10 years
I'm having issues with my icemakers again. The thread listed below was about the water tank freezing along with the bottom icemaker line. Replacing the fan fixed that issue.
This is one that freezes the ice ball on the back. To help that I have placed insulation over that spot and sealed it pretty well. I don't think I have ice anymore but I haven't taken that off to actually check. I know there's no water making its way down the back side anymore.
After the fan fix the lower icemaker worked fine awhile. I've had the top icemaker turned off because it melts and refreezes the ice cubes together causing a big mess. The container actually got cracked trying to get ice from it out the door. I'm guessing that has to do with the insulating kit available to fix the poor factory insulation around it. Now I have other issues.
The bottom icemaker line froze up again where it goes down to the freezer. Thinking maybe the freezer door might have got left open a bit I thawed the line out and it worked again for a few days. Then it froze up again. This time I found ice frozen in the bottom of the refrigerator. That pointed me towards the drain. Checking it found it was not stopped up. I then noticed water dribble running down the inside back wall. I traced it to the upper icemaker. It has some ice hanging from the bottom and water dribbles out of it down the back wall. I placed a towel just under it to see how much water was actually coming out and it has gotten pretty saturated. It's also frozen. I put a thermometer right under the back of the icemaker it shows temps in the 20s consistently. I can feel cold air blowing out of the bottom of the icemaker housing. My first question is why is water coming out of the upper icemaker. I'm guessing possibly condensation but not sure but why would it leak out the back. And why is it leaking cold air? Deteriorating insulation maybe? This has just started recently. Also, the cooling fan in the upper icemaker still runs even though it's turned off. I assume this is normal. I don't think the upper icemaker leaking has anything to do with the lower icemaker line freezing up because I stopped the water from running down the inside back wall with the towel and the lower line still froze up. There's no ice in the bottom of the refrigerator now either. But I suppose anything is possible.
Another question would be can I eliminate the upper icemaker all together? Shut off it's cooling and fan? I don't really need it if the bottom one works and it's a pain in the rear to keep ice flowing freely in the container out the door.
The next question is what's causing my lower unit line to freeze again. It seems to work fine for a few days then randomly freeze again. I've gotten pretty good at taking it out and thawing it. But I don't really understand why water stays in the big fill tube to even freeze. Obviously freezing air is going to go up the fill tube from the freezer. Any water that is somehow trapped in that tube would likely freeze. Shouldn't it empty out below where the tube turns down inside the refrigerator when it fills? That's got me somewhat confused.
Sorry for the book. This is the worst appliance I've ever had. I'm ready to replace it but don't really want to spend that much right now,.
Thanks.
www.applianceblog.com
Thanks.
FIXED - Frigidaire Refrigerator LGHB2867PF2 water tank freezing.
My unit had been humming along fairly well, except for the top icemaker but that's another story, until one day last week when the bottom icemaker stopped making ice. I assumed a line was frozen since it's happened before when the freezer door wasn't closing properly. All new door seals fixed...
