- LGHN2884MF4
- Frigidaire
- 6-10 years
Hello: I am new to this forum; so glad to have found it!
I have a Frigidaire LGHN2844MF4 refrigerator; the refrigerator occasionally leaves a small puddle of water on the floor, on the right hand side of the fridge.
When I placed my finger in the drip pan, it was bone dry. I then looked at the bottom interior panel of the freezer, to find a sheet of ice...my thinking is that the water isn't draining into the gutter, down the hose, and into the drip pan: it's collecting at the bottom of the freezer. Once the bottom panel has no more capacity to retain any more water, the remaining water leaks onto the floor.
There's no access panel on the inside of the freezer to gain access to the gutter; I unscrewed the rear panel, and it revealed the condenser coil, but there was no way to get to the drip gutter.
I'm a novice at best, so I didn't want to remove the condenser coil...what I did was unplug the fridge for 26 hours, hoping the gutter would defrost; it did not, because ice is starting to reappear on the interior bottom of the freezer.
I don't want to tilt the refrigerator on it's side, and work on the gutter from the refrigerator bottom; any ideas?
Thank you
Thank you
