LGUS2642LF2 Frigidaire Gallery Ice Dispenser Doesn't Stop
mcdonaldvm
Georgia
LGUS2642LF2
Frigidaire
My Frigidaire ice dispenser frequently will not shut off. The flap stays open and the auger continues to run dumping ice everywhere. If you open the freezer door it will stop which allows me to reach in and close the flap, then I can close the freezer door and all is good until next time. My wife has told me that she has also had it happen when dispensing water but that is much less common.
I removed the dispenser and checked the dispenser paddle microswitch continuity with a meter. I never got it to stick so it appears to be good. I also checked the microswitch on the door flap and it also checks good. The solenoid and linkage for the door all work smoothly, but I lubed it anyway with no change to symptoms.
I replaced the main control board barely over a year ago because it would not dispense water (ice dispensing was OK) and it took care of that issue.
Does this current issue sound like the dispenser control board is now bad? Thanks for any guidance I can get.
Here's the part you need:
