FIXED Lights on doesn't work properly GE Dishwasher GDWT668V00SS
cloroxmartini
Phoenix AZ
GDWT668V00SS
Just replaced the tub gasket and ran it and the dishwasher ran fine. A day later, when I close the door, all it does is fill the tub with water, won't run properly.
When I close the door I can hear a click (the dishwasher is a quiet running dishwasher), like something is engaging, but not the washing of the dishes. I opened the door and bailed water, tried again, still didn't work, filled to almost overflowing, so bailed water again.
Buttons are across the top of the door. There is an on/off button to the right, and several setting buttons to the left, and an operating indicator light on the front of the door (green/yellow). They all work.
When I turned off the on/off button and shut the door, the dishwasher power drained, which is nice, I didn't have to bail water anymore.
I returned the next day and tried it all again getting the same results.
I cannot find any trouble shooting guide that addresses this issue so trying to find out what's wrong with it.
Thanks in advance for your help.
Try to run it in service mode, your tech. data sheet tells you how. The tech. data sheet should be located either inside the control panel or down at the very bottom behind the bottom access panel.
Usually when the machine won't run a cycle but will run in service mode the problem is with the control module.
Here's the control module for your model:
Control Module WD21X10517
In case you can't locate yours, Here's the service manual for your model: https://drive.google.com/file/d/1N5iqBZmg2_YogWQQZC0eC79hmfkfRUio/view?usp=sharing
Service Mode is on page 37.
Ok, sounds good.
cloroxmartini
Phoenix AZ
I let the unit fill the tub a little then put it in service mode. I operated the main pump and it worked, spraying water inside the tub. I then operated the auxiliary pump and drained the unit. I too the unit out of service mode and it reverted back to the original error.
Then the control module is the culprit.
Yes, I posted the link to the control module in post #2 above.
Let us know how it goes after you replace it.
Excellent @cloroxmartini glad to hear the new control module fixed it.(y)
