LMHM2017ST LG Microwave In-door display erratic
jmlalley3
Maryland
LMHM2017ST
LG
How do I get the door apart to replace the display. It occasionally gets very dim. This is fixable by pressing the upper right corner of the screen firmly. It stays bright until the "next" time.
I do not think it is a cable issue but rather a display issue. Please let me know if you think other wise.
Cheers
Joe
jackofalltrades
NY
--->LG Microwave LMHM2017ST Repair Parts
You have to use a small putty knife or butter knife to pry the trim away on the inside of the door. The plastic trim piece that runs around the complete perimeter of the inside of the door. That's the hard part. After that it's pretty self explanatory once you see the door with the trim removed.
