FIXED LMHM2017ST LG OTR in-door display erratic
Traveler62
Kansas City
LMHM2017ST
LG
Correct Model #LMHM2017ST. Display will be fine for days, then it starts showing weird characters. Open and closing the door usually fixes it. Assume it is a bad connection to the door. Checked the ribbon cable and connection in the door portion and was fine.
If I remove the microwave, will I be able to access the other end of the cable and check that connection? Is there a good detail of how to get to these connections?
You can remove the outer case. This is for a similar model but should be the same as yours:
Remove the two vent grille screws.
Remove the four screws securing the oven case to the oven. (Four on the top, one on the right side.)
Remove two screws on each side of the base plate.
Remove the four screws holding the outer case to the back of the oven.
Lift the outer case carefully from the oven. Store it to prevent damage while you are working on the oven.
Traveler62
Kansas City
Finally had the Microwave removed to replace the backsplash in the kitchen. Removed the cover and didn't see any connectors loose, but removed and installed all of them anyway.
Getting the cover back on and lining everything up is not easy. The bottom assy with the sliding vent all moves around once apart. Had it back up now for two months and haven't seen the display issue return, so hopefully it is fixed.
Thanks Rick for the info.
