FIXED LMV1762ST/01 LG Microwave works, but no heat
Luke99
Chicago
LMV1762ST/01
LG
Microwave works, but does not heat.
Only 1 year and 3 months old.
I have replaced switches, diode. Checked transformer, magnetron.
Magnetron seems ok when measured with multi-meter.
Relay shows 120V
120V comes to transformer, output is good.
What I have noticed is little burn on the connector to the magnetron.
When I disassembled Magnetron I noticed it had some brownish residue on the antenna
Should I replace the magnetron or it could be something different.
Thank you and appreciate your help
It's probably the mag tube. Sometimes the tube will show less than 1Ω but opens when it's energized. If you have 120 VAC on the primary side of the HV transformer you can use the process of elimination using this diagram:
I swear I put that part link in. Or maybe I didn't. Getting old sucks!
LOL, Join the crowd of 50 and older Rick, The golden years, LOL. That's the main reason I started ApplianceBlog back in 2004 I noticed my memory wasn't as good as in my 20's. I wanted to blog all my repairs so not to forget down the road, then everyone thought that was a good idea and joined in and the forum we use now was born.:)
Luke99
Chicago
I've replaced the magnetron and the microwave started to work again.
Also I've replaced the switches and diode because they were cheap, so why not to change them.
Thank you for your help!!!
