LMV2053ST LG microwave... no power at all, chances fused, still no power
LMG
Ocala FL
LMV2053ST
LG
LG over the range microwave LMV2053ST.
The bottom light bulb was burnt so I proceeded to remove it however I broke it in the process. Since the points of the bulb were still in I had my daughter shut off the breaker on the wall, and I used a needle nose pliers to remove them. BOOM! It sparked and popped loudly, my daughter had turned the wrong breaker off. After that there was no power at all to the microwave. I changed the ceramic 20A fuse but still no power. What else should have check or replace?
Check for power
Has anyone confirmed power is getting to the microwave now?
LMG
Ocala FL
I put the new ceramic fuse in then plugged the microwave in, no lights no power. Is there a different way to check if there is power getting to it?
Measuring with a volt meter or using an outlet tester or test light where the microwave plugs into the wall outlet would be testing. Plugging a lamp or other electrical device into the microwave's wall outlet to see if it worked would be a way to test if there was power there.
LMG
Ocala FL
Thank for the replies.
The outlet has power, I took down the microwave and put it on the counter using another outlet which also has power.
If the unit is not working at all and power is definitely at its outlet and the internal fuse is good, a failure of the electronic control may be responsible. I can't say whether there could be any other possibilities without seeing the unit's wiring diagram which I don't have access to. On most models there aren't any other components that can stop all functioning.
JMO
Check cavity thermostat
Ok, I located a service manual for your model and the wiring diagram looks to show 2 thermostats, one of which might stop all power to the unit if it failed. Although not designed for that specific purpose, it might have been damaged because of the short. (It normally fails by getting too hot but it could be a weak point in the electrical circuit and have failed due to the short.)
The one referred to as "Oven cavity thermostat" is the main one needing resistance checking (with an ohm meter). I am not positive exactly where it is located but likely attached onto the oven cavity wall or ceiling. The other similar looking thermostat is mounted on the magnetron tube but if it failed should only stop heating.
LINK > Oven Cavity Thermostat 6930W1A003D
LINK > How do I test for continuity?
If it tested Ok than I can only think the electronic control itself might have been damaged by the short. Unfortunately the control PCB looks to be discontinued. I did find one new one still available for sale if needed:
LINK > LG LMV2053ST Control PCB 6871W1A419K
