LMX21981ST/01 Need source for ice maker fan ADJ36762901
South LA
LA
LMX21981ST
LG
Hi all,
I really dislike LG refrigerators. Icemaker fan went out (giving Er1f code) and unable to find source to purchase one - no longer made...
Also, water drips on floor and ice fills bottom of freezer. The drain hose is not clogged. Not sure what is causing and how to fix.
All help with both is most appreciated.
Yes, the ice maker fan is no longer available: ADJ36762901
You can go to your local appliance parts store and see if they can match up a universal ice maker fan motor.
If the drain isn't clogged up, then it has to be coming from the ice maker itself, that's the only other water source in the freezer.
South LA
LA
Thanks Jake. How likely am i to find a universal fan motor to fit?
and The drain tube(if im right) is the one accessible from unscrewing the rear panel behind the fridge? Is that correct?
I don't know, that's why you need to go there or call them and find out.:)
Yes, correct.
