- LMXS27626S
Hi all, my first post here...
I have a 2015 french door refrigerator LG model LMXS27626S, with the whole ice making system, including the ice tray, inside the left door. In the past few weeks I started having water on the floor, and I have seen that the leak was directly connected to using the water dispenser, if we don't use the water there's no leak.
After checking around I found that the leak comes from inside the bottom of the left door, where there is a kind of hidden compartment which is accessible opening the door and lifting away the bottom shelf. In this compartment there are electric wires, some tubings and a plastic reservoir the size of a glass. The place is all wet, so I'm sure that the leak comes from one of the connections there, but I have no way to see it in action because of course the water dispenser won't work with the door open, and therefore I can't pinpoint where the actual leak comes from.
I hope that my description is good enough... Any suggestion to how to proceed?
