hot fridge
- LMXS28626S
- LG
- 1-5 years
My fridge isn't cooling and I'm hoping it's the PCB rather than the compressor/sealed system.
I woke up to find the ice had melted and it was not cold in the fridge or freezer. The compressor runs but isn't cold, and sounds normal while operating, compressor fan is operational. The evaporator fan is not running, unless test mode 1 is activated (and then all fans work normally). No error codes or LED morse code on the PCB. No leakage or weird drips, coils are clean.
When I ran through the PCB check I didn't get 200 V at Con201, rather the volts slowly climbed to about 130 before dropping off completely.
How can I know if the compressor is the issue or if the PCB is the issue?
