- LMXS30776S
- LG
- 1-5 years
Thanks in advance for reading and helping with this. This may get pretty long...
I bought this LG LMXS30776S/02 refrigerator (Product Code GR-J31GHSJM.ASTCNA2) in Nov 2015 at Lowe's and after reading many of the posts from here, I realized that was a terrible decision...
Around October this year (2017) the refrigerator started making unbearable noise. Called a service guy to come over, and he took off the back panel in the freezer compartment and it was full of ice. He used a hair dryer and melted the ice away and the noise was gone. Then he replaced the defrost thermostat and the PCB board at the back and the defrost started working.
However, couple days later, there was an error "E rf" (pretty sure about this, NOT Er rf) popped up. By the time I checked the freezer was fine (food was frozen hard) but the upper refrigerator compartment was 63F. Then I found this forum and learned it was the freezer evaporator fan (now i know this should be the evaporation fan). I found the service manual and looked up the diagnostics and apparently the service manual says there should be 3 wires for the evaporation motor on CON6 but I have 4 wires! I went ahead and tested the voltage anyway, assuming the black and red wires are for the 12 DCV and the other purple and yellows wires are for the feedback. The board fed around 9V to the motor. The feedback reading was 5V when the motor wasn't plugged in. So the board seems functional. Also I reset the power and clicked the test button for 1 time to activate all the fans. The ice maker fan spin fine but not the evaporation fan.
then I ordered an evaporation fan from appliancepartspros, according to their part number index system, i ordered EAU61524007. When it arrived, it had only 3 wires on it instead of 4! I had to take out my evaporation motor in the freezer compartment and find out the actual part I need was EAU63103204. When it came in, I went into the test mode, no dice.... I have a DC power supply at home so I wired the power supply to feed 12 DCV into the motors' black and red wires (both polarity), none of the three motors would spin. Also measured the voltage from the feedback wires and it was 3V. My question here: does this mean all three motors are faulty?
Last night I was doing more readings here and wanted to check my refrigerator fan. I removed the top back cover and went into the test mode. It turned out the refrigerator fan wasn't spinning either! I removed the fan and again it has 4 wires on it. I tested the voltage between the black and red wire and it read 15V. Then I hooked the fan on my DC power supply and it spins fine at 12 or 15V. Plugging the fan back onto the refrigerator, no dice again.... I am really confused.... I didn't put the fan back into the center duct unit, instead I laid the fan in the refrigerator and went to bed. When I woke up this morning, the refrigerator got to 28F.... but the freezing compartment wasn't frozen at all. A new error "E FF" popped up this time.....
Oh also earlier this week, I had the service guy come back again and replaced the PCB board (he thinks it was a fault PCB board) but everything remained the same.
My suspect:
since both the evaporation fan and refrigerator fan I found online (by looking up the refrigerator model number) have three-wire harnesses, and the actual parts on my refrigerator have four-wire harnesses, I high suspect the board that the service guy put on wasn't the right one. I mean, the board he put on may only have three pins for each fan instead of four pins, in my case. I haven't talked to him about this yet. Last time he said he has disposed the original PCB board and I don't know exactly what's the part number on that original board.... I couldn't find any information anywhere either... The PCB board the service guys put on is "EBR78643401"
Thanks again for taking your time to read through this and any suggestion would be greatly appreciated.
Lesson I've learned so far, never buy LG refrigerator!!
My suspect:
