Looking for information on Westinghouse refrigerator.
Michale Medina
Montana
I recently bought a new house and while i was cleaning out one of the rooms I found this fridge in the back corner. I am looking for help in finding the date of the fridge and were i would be able to get replacement parts to refurbish.
PLATE ON BACK READS
MODEL-LS-6-40
Style-991387
SER.-WA886354
UNIT MODEL NO. J-5
MAID IN U.S.A
Thank you for all help in advance.
I am looking for help in finding the date of the fridge...
It looks like circa mid 50's. Look for a metal tag around the compressor area sometimes you can find a patent date.
...and were i would be able to get replacement parts
The only parts you'll be able to find is universal door gasket material and universal replacements for the compressor relay and maybe the thermostat. If you need cosmetic parts you're probably out of luck. You can look for another one for sale and make one out of two.
Michale Medina
Montana
I'll take a look around the compressor see what I find.
Darn oh well on the parts everything seems to work on the fridge just need a new door gasket.
I will update my findings soon as I can.
Thanks for the help
Michale Medina
Montana
the gasket does look like the image.
I opened up the fridge and found this plate tag also
25397 MAID IN
(11-9-38) U.S.A
REFRIGERATION UNIT
MODEL J-5
SERIAL 4257120
TEST PRESS 200
REFRIGERANT F12
UL
STYLE 963005R
VOLTS 110
AMPS 3.2
CYCLES 60
SEE PATENT RECORD ON PATENT PLATE
WESTINGHOUSE ELECTRIC &MFG COMPANY
SPRING FIELD, MASS, U.S.A
G
Guest
Guest
Check out Antique Appliances in Georgia for the door gasket. They have a website. Model number LS-6-40 is a 1940 model having a 6.2 cubic foot capacity. It has a painted (Dulux) exterior, is 58 inches tall, and 29 inches wide. All three racks are present. Looks like the only thing missing is the drip tray that goes under the freezer box. A very nice fridge you have there! Hope that helps!
