Indiocaribe
imported post
I heard a metallic noise, like something loose when the washer started- just after finishing filling up. I turned it over and removed the coupler, which was bad and found the loose pin. Also, what is the easiest way to reconnect the motor/ drive assembly? I removed it to facilitate the installation of the coupler, due to the little space in my Kenmore model 110 92281110. It's about 1/2" inch away from the 3 supports and the bolts do not reach. When I push the assembly, the whole washer moves forward. Thank you.
