Loud Buzzing in Samsung Over the Range Microwave
cxanthos
San Diego
SMH9151
Samsung
My Over the Range Samsung microwave has developed a very loud buzzing sound whenever it is heating. When running at cooking percentages the buzzing cycles on and off corresponding with the heating cycle. Despite the sound, it seems to heat fine. Any ideas? Is it safe to continue to use? Thank you.
It sounds like it might be the mag tube, but it could be any of the high side components. It's safe to use. There are a lot of safety devices built in. Is the buzzing getting louder or staying the same?
cxanthos
San Diego
It was tolerable for the last few weeks but now it has become really loud in the past couple of days.
Thanks.
It's going to be difficult to figure out what part you need while it's still heating. The diode is the most common noise maker but when it goes out the microwave doesn't heat it just makes a loud hum. The noise cycles on and off when cooking at 50% power, right? Does it completely stop or is it barely audible? Can you access the high side components or will you need to take it down? Do you have a VOM? (Volt Ohm Meter)
cxanthos
San Diego
When it is at 50% it cycles completely off and then full loudness. The buzzing is not audible at all when it goes into a rest cycle. I will need to take it down to access the high side components. Yes I do have VOM.
Thanks.
cxanthos
San Diego
I checked the serial number and it's an S9 (September, 2009), so I guess it doesn't apply. It does look, however, like I can access the upper components without having to take it down.
Thanks.
OK, Unplug the microwave and short the two terminals on the High Voltage Capacitor together. Let's start with the easy obvious things first. Check for any loose screws on the fan motor and bracket. Make sure the fan blade isn't hitting anything and that's not loose on the shaft. Check all the screws that hold the High Voltage transformer in place. Make sure they are all tight. Next check the H.V. Diode. It's easier to just remove it from the H.V. capacitor and ground screw If your meter has a diode check, touch the probes to the two ends of the diode. You should briefly read some resistance one way, then switch the meter probes and you should read open or 1. When you reinstall the diode make sure the ground screw is tight. Try running the microwave with the cover off and see if you can tell where the noise is coming from.
cxanthos
San Diego
Finally got it all taken apart. Diode and HV capacitor check out and magnetron is quiet. It's the transformer that's making all the noise. The metal base plate it sits on works as a great sound amplifier too! I placed the order today for the replacement part at appliancepartspros.com and they had it in stock. I also noticed the diode ground screw is a sheet metal screw and doesn't get very tight. I'm going to replace it with a machine screw and lock nut to make sure it stays tight. Thanks for your help.
boomster
Brunswick
Help!
Mine is having the exact same issues and I'm 99% sure it's the transformer. Could you tell me what part number is the transformer for this microwave please?? Was it easy to replace it? It's getting so loud and if it's an easy fix I'd rather do this myself then buy a new microwave.
THANK YOU!
