Loud noise
dairycow123
california
last night when i was using microwave there was a loud pop and now there is a loud hum, when running. if i put the power lvl on zero and turn it on, no noise. and a few days ago i would turn it on and the timer would count down with no noise what so ever, however it started working again as normal. does this sound like a magnatron issue or something else. i havent taken anything apart yet.
A copy:
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
If needed:
Magnetron-6324W1A001H-01359853.jpg LINK> Magnetron
Diode-6851W1A002E--01638081.jpg LINK> Diode
1) They can "test" or ohm ok and still be bad!
2) Maybe high voltage transformer....but we probably replace 1 transformer to 100 mags and diods.
