LRE30451ST LG electric range ..no power
Birch
Long island
LRE30451ST
LG
My lg range recently lost all power while broiler being used. Through web searches, it looked like the thermostat could be bad. Here is my confusion.. based on parts/schematic the thermal fuse could be the problem. When I looked at my range there wasn’t anything in the place (rear center) shown on the schematic. Also nothing that matched it anywhere else.
Is It possible that it is somewhere else? Or that I don’t have one since mine was probabaly one of the originals.
Any help or thoughts to repair is greatly appreciated.
Cheers!
It should be in the very back, just pull your range out from the wall, then unplug it, then remove the back access panel and you should see it.
Its #5016 here: Parts for LG LRE30451ST: Section 5 Parts
Here it is for your model:
6930W1A003X
You can use a multimeter and ohm test it for continuity, this video shows you how: Thermal Fuse Testing Video
