FIXED LRE30451ST LG Range Oven Overheating
Bazski2003
Upstate NY
LRE30451ST
LG
Hello, My wife set the oven to 350 yesterday to bake cookies, preheat to 350 and beeped and cookies went in, a little bit later we smelled burning, cookies were black, broiler element seemed to remain on and stove was extremely hot. The stove still said 350 but was not cycling on/off and temp was over 500 degrees. Shut it down and it cooled off, stove was unplugged and took the back off, tried to test the temp probe, but pins of my ohm meter didn't fit in the connector. I see online how it could be a number of thing. Was wondering any way I could narrow it down, hoping to get another year or two out of it. I also saw while researching that this model and my serial was involved in a recall that I never had done.
Thanks for any help.
I'd first ohm test your oven sensor, if your meter probes are too large, they make small adapters you could get.
You'd pull the Range out from the wall, then unplug it, then remove the back access panel, then you will see the little electrical connector that snaps to it, then unsnap it and ohm test the oven sensor part only.
Here's the oven sensor for your model:
Temperature Sensor 6322B62214A
If the oven sensor ohm tests good, then its possibly the relay board that controls the on/off cycle of the heating element inside the oven.
Here's the relay board for your model:
Relay Board 6871W1N012B
Bazski2003
Upstate NY
Thanks so much Jake, it ended up being the relay board, replaced and back in business. Saved me from buying a new stove, much appreciated!
Excellent, glad to hear the new relay board fixed it.:)
