FIXED LRE30755ST LG Range surface burner difference
tmol
florida
LRE30755ST
LG
hello. i have a right front duel burner that is open it needs part # 5300w1r009a i have a 5300w1r008a same part # but the 9 @ 8 are different at the end can it be used for a temp use until i get one. is it much different it looks the same?
thanks tmol:3:
The "8" one appears to have one less terminals on it...
Radiant-Surface-Element-5300W1R009A-01057363.jpg Heater,radiant 5300W1R009A
Radiant-Surface-Element-5300W1R008A-01057355.jpg Heater,radiant 5300W1R008A
wildimaginations
Danville, California
5300W1R008A is for the full size 8" element
5300W1R009A is for dual element. 8" and 6" element size use. For temporary use, connect the wires so the outer ring connection is left out and the connector is taped over.
