- LRE3083ST
- LG
- 6-10 years
I have an LG oven that is approximately 6 years old that is not heating to the correct temperature. The oven pre-heats in the normal amount of time and says that it has heated fully, then does a normal re-heat cycle. This is the case for both convection and regular bake. I have manually adjusted the temperature to the maximum 35 degrees, but the oven continues to gradually deviate from the correct temperature. The temperature does not fluctuate once it gets to the temperature it thinks it needs to be at. The symptoms are that the oven was not cooking properly and I have verified the temperature with a precision oven thermometer.
I also replaced the thermostat, thinking that the resistance reading was not correct, but the problem is identical with the new thermostat.
My next thought is the computer board. I wouldn't think it was the heating coil, because the problem isn't with the oven getting hot -- it is with the oven reading the temperature correctly. Am I correct?
