FIXED LRE3193ST LG Oven Display temp only shows 1 digit
zamboknee
Des Moines
Update: the new board arrived, I replaced it. Everything works except it's still taking forever to preheat.
I have a thermal sensor coming soon. Will replace that and we'll see.🙄
Ok, then you must of had a problem preheating the oven for bake for this display issue started and you just forgot about it, because it makes no sense why solving one problem makes another problem. LOL
If you put your oven on BAKE at 350 degrees, it will take about 20 minutes for it to preheat, that's on all ovens, including my Maytag in my Kitchen.:)
zamboknee
Des Moines
Didn't have any preheating issues before display problem. None
Oven was working great, then all of a sudden the display digits (original post)problem pops up.
Did you check for 240 volts across the bake element terminals when the oven is ON BAKE at 350 degrees?
If not, do so now, put your meter on AC volts and check for 240 volts at the bake element terminals in the back of your range.
Just put 1 meter lead on one bake element terminal, and the other meter lead on the other bake element terminal and tell us what you get.
Huh? I just explained how to do it.
zamboknee
Des Moines
So I went to run the multimeter on the element terminals and found, behind the shield that covers the sensor and all that, a wire that was unplugged. Strange because I had never gotten into this area ever.
Plugged it in, tested a preheat and it works!
BINGO! Excellent, I thought I was going crazy. LOL
