Consumerbot7237
- LRFCS25D3S
- LG
- 1-5 years
This is a French door model, with ice maker in the freezer.
I've had a wireless thermometer installed to monitor the temperature in the fridge and freezer, and noticed that despite setting the fridge temperature to 37ºF, it was sometimes dipping down to 33ºF, at risk of freezing the contents.
In order to keep that from happening, I've since set it to 40ºF, and kept an eye on it. I've since seen it below 34. I've attached some charts that show the fridge and freezer temperature over the course of about 10 days. The spikes in freezer temperature correlate to brief periods of about 260 watts higher power usage, so I presume those are defrost cycles. I thought that might be the cause of the variations in fridge temp, but as the charts show, there doesn't seem to be a connection. In these charts, the fridge has been set to 40ºF, and the freezer to -4ºF.
On the second chart, Jan 29th, the temperature stayed between 33.8 and 35. That's actually wonderful, but as you can see, it doesn't stay there. If I change the set-point lower, I'm afraid of ruining the contents by freezing them. Is this normal behavior for this fridge? For all of them? Or is there a possible malfunction that could be fixed? I've got technical abilities with electronics, but would rather avoid doing anything that could jeopardize the warranty.
