LRG3061ST/01 LG GAS RANGE Oven not working properly
gferr
LRG3061ST
LG
I am having an issue with LRG3061ST/01
The stove takes a while to kick on, i can see the reddish light on the bottom but it takes about 2 minutes to actually start heating, when it reaches say 400 degrees, it rings but then does not stay on to keep the temperature, the temperature still says 400 but if i turn it right off and on the temp says 275.
thanks
gary
jetengine
Hi Jeff,
I have the same range (LRG3061ST/01) and I'm having the same issue where the oven won't keep temperature. Pressing 'Cancel' and restarting the bake preheat cycle will once again raise the temperature.
I have changed both the over temp. sensor and the igniter - however, the problem persists.
In this thread on a different oven, they fixed the issue by changing the circuit board that controls the oven:
I want to try that, but I'm unsure which of the three boards I found for our model would control the oven and heat cycles. Do you know which one it would be?
links not allowed
