LRG3085ST LG won't heat
BamaGary
Birmingham
LRG3085ST
LG
I asked this in another thread with a similar problem, but thought it might be better to post it's own thread. I have a gas range, it will always preheat, but most of the time it will lose temperature, never gets too hot. The display will continue to show the desired temp, say 400, but if you turn it off and back on it will show 200, or whatever the actual temp is. At that point it will not heat back up. It seems to only preheat again after reaching room temp. I have replaced the thermostat and the oven worked as it should a couple of times (coincidence I'm sure), but it's back to the exact same problem.
Keep us posted.
