LSC27925ST Compressor lines are frosting terribly
Whiteke12
Minnesota
LSC27925ST
LG
Lines coming from compressor are all frosted up. Fridge is cooling at correct temps. Compressor is not overly hot
image.jpg image.jpg.
Appears there is also an error on display. 4th line on display is lit. I believe it's a defrost error.
Can these be related or are these separate issues?
Whiteke12
Minnesota
I figured out the error. The defrost control assembly wiring was unplugged causing error and unit not to cool. The frosting of the lines is still there. Could they have simply overfilled? Would it be wise to evacuate a small amount to see if there is any change?
Florida
Hi . I am new to this forum. I hope someone will help. I do have exactly the same issue. Please let me know how were you able to fix it.
