FIXED LSC5622W LG Range How do I check/replace the Hidden BAKE ELEMENT?
Zgoodfella75
Nc
That's perfect.
Normal is 15 to 20 minutes to preheat on all ovens.:)
Oven won’t hold the temp. Preheats never reaches desired temp over say 375. Then slowly comes down.
I have tested my bottom element. Broil topeement And temp sensor. All checked out good. Is it the relay board ??
If the oven won't reach the correct temperature then it's losing the voltage to one or more elements. The relays are marked on the board, BA=Bake BR=Broil DLB=Double Line Break. You're measuring the output voltage to the elements.
Zgoodfella75
Nc
I changed the relay board. And now the oven won’t heat up at all. Stove top still work. But not oven. Any thoughts
OK do you have the exact same model machine as the original poster LSC5622W? Where did you get the board? Measure the voltage on the relay board between L1 and L2. Is the voltage 220 VAC?
