LSG4513BD LG Range won’t maintain selected temp.
Ranger
Mount Pleasant
LSG4513BD
LG
If I set oven to 350 degrees after preheating temp drops 30 degrees before reigniting . Have manually adjusted according to the owner manual to 370 so now when oven is set for 350 it preheats to 370 but only momentarily then drops 30 degrees before relighting . Any ideas . Thanks, Jay
Added complete model number
Model Number LSG4513
That model number is incomplete. Please post the complete information so we can look it is to see what appliance design you're dealing with.
You can find tips for locating the model and serial number identification tag on your appliances at the following link:
LINK > Model Number Tag Location Guide
Someone will need to watch the operation of the oven burner and ignitor. It could be that the burner is not light again right away after cycling off.
The burner should ignite into flame 45-90 seconds after the ignitor starts glowing. If it's taking too long to ignite after the ignitor is glowing, the ignitor might be 'weak' and need to be replaced.
LINK > LSG4513BD Oven Ignitor MEE63084901
If the ignitor isn't even glowing when the oven should be coming on again, the functioning of the control system might need to be investigated.
