FIXED LSSE3026ST - Outer burner of the double burner does not turn on
boomeral
USA
LSSE3026ST
LG
Hello all,
The inner burner of LSSE3026ST is working, but the outer burner has stopped even when knob turned to dual burner-on mode.
I replaced the burner, but the problem has not been resolved.
What other problem area should I investigate?
Is there a circuit diagram available for this model?
boomeral
USA
I guess it was a difficult question that no one was able to answer - which is totally understandable.
For those of you might run into this issue, the solution is to not making operator error.
Take lots of pictures before touching anything since no help is available from LG or any other resource.
I swapped the two wires - shown in the attached picture. I am glad it did not cause the wire-melt or fire.
It was difficult to trace back the error since there was no reference schematic available, but I managed to debug it and put it back to its original place.
Both of the dual-burners are now operating as usual.
Which burner was it? You have 2 double burners Front-Right and Front Left?
Here's the parts diagram below was it 330M or 330H?
Thanks for letting us know.:)
