LTF8000FE0 Code E6F not in my manual
dandrlp
WA
LTF8000FE0
Frigidaire
Our Washer turns on and off at random. When reading error codes I saw E6F. That code is not in any manuals I could find.
The power to the board between J2/2 and J1/1 is constant 120V. Also checked power to door lock is 120V at J3/3. I do not see any problem with door lock.
Control board problem?
Any troubleshooting suggestions?
Louis
Hi Louis,
Your correct that error code is not listed in your error code list.
So the problem would be the main control board.
Here's the main control board for your model you can order here:
Main Control Board 137007000
