FIXED LW1510ER LG Window A/C Compressor does not turn off
Man, there is soooooooooooo little info out there on that model# :(
I did find this, hope it is like yours...
Main power control board
Ronan
San Antonio
Hello all,
Jeff, Rick I was hoping y'all could help. I have a LW1516ER that seems to be having the same problem as everyone above. I've tried searching for that board replacement but it also seems to be discontinued. Just wondering if y'all might be aware of where I might be able to find one. I haven't had a chance to open the case to verify the board number. One site I came up on gave a substitute of EBR39283903, not sure if that's correct though. Thanks in advance.
Ronan
San Antonio
So, I opened her up to check the board, it seemed like maybe the wire coming from the compressor to relay was loose as it gave a "click" when pushed in. Not sure if actually loose as I have no prior reference. After reassembly it actually seems to be working fine. It was also off and unplugged for about 8 hours. Possible it was just a loose wire or would it be prudent to just replace the board anyway?
A loose wire connection can cause all kinds of problems with open circuits. Yours however, is relay contacts sticking together and a loose connection won't cause that. The problem will probably pop up again.
It won't hurt it any more than it is now to just let it run until it craps out again.
TracyPerrin
Louisiana
Hi Rick, board is in but when in heater mode it’s not blowing hot are just lukewarm. Do you know where I can get a wiring diagram for the board.
No such animal exists. At least not that I know of. Manufactures want you to replace it, not repair it. With the exception of a few boards, I've never been able to find a board schematic and many members here have also looked for board schematics. They just don't exist.
Daniel7378
Acworth, Ga
Hello guys,
I have the same issue as the original poster but I have replaced the circuit board with a brand new one and my compressed still runs continuously unless I unplug from power. What’s the next step? Seems to be another control board deeper in with relays and diodes and resistors etc. should I check something there? Any advice or suggested parts would be great!
LG LW1516ERY7
I have already replaced the PCB display p/n: 08-04608-90055
Thanks in advance!
FTV
Pearce, AZ
Hello,
I am having a similar problem, my LG LW2515ER continues to run when power is turned off. The only way to turn it off is to unplug it. Thank you!
