LW1816HR/00 LG window unit - What is this part called?
Rwhitt36
Houston
Lw1816hr
LG
What is this part called? As well as can it be purchased separately? Find it in attachments circled in orange.
It might just be an electrical junction bar. Can you post an image from a different angle?
Are there any markings on it? If so, post a photo of them too.
What's on the other side of the panel it is mounted to?
Here’s a different angle and the condition it was found in. Markings unknown as my attempt to mend it destroyed the ability to see them.
No, showing its bottom doesn't help. I would need to see what the terminals are connected to. It might be just a busbar??
Busbar examples
That’s it. Just the top isn’t opened. Found it snapped/crack but no signs of a spark. Fuse blown though on circuit board. New circuit board didn’t fix the issue. Is this the culprit?
Left to wonder what would be so forceful as to crack the shell. No evidence of prior servicing.
All busbars do it connect the wires together that are attached to the same metal part. The plasic does nothing and just insulates the metal parts from touching anything else.
Just the plastic being broken would not affect any functioning.
That wouldn’t do anything
What??
IF it is a busbar, the plastic is just an insulator. Its only function is to insulate the wires attached onto its terminals.
Broken plastic would do nothing in itself if that's what you're referring to. It might make it hard to mount but nothing else.
