Magic Chef 3468XVW
jmccall
Grayslake, Il
I've been having trouble with the oven reaching and maintaining temperature. I believe that the igniter may be failing and need to access it so that I can replace it. I'm not clear on how to remove the bottom pan to access the igniter. Any help would be appreciated. The oven is a Magic Chef 3468XVW.
That lower bottom pan should come out by pulling it out and lifting up on it.
Here is a link that should help you more on your range:
http://www.applianceaid.com/gas.html
