Magic Chef MCO165UW not turning on
microkat29
phoenix
MCO165UW
Magic Chef
Can someone help me trouble shoot my microwave. I used my stove to heat up my apartment and the automatic fans went off and then my microwave shut off and wont restart. Do you think its the fuse? Or does anyone else know how to figure out this problem?
Wouldn't a small heater be better?!
Check the thermostats on the inside of the bottom/base....one is open and closes to turn on the exhaust fan if the bottom gets too hot...other is closed and will open to protect the microwave.
Thermostat-3518906800-01034967.jpg LINK> Thermostat
Thermoprotector-3518905500--01034943.jpg LINK> Thermal cut-off, normally open
A25 and A27
