Magic Chef Microwave MVP III vm11eb-8p
splicedude
Have power to unit. Display comes on and accepts input. The lamp in unit interior off and the microwave function (start) does not work. Basically the unit is dead for heating and cooking. The fan and bottom light work fine. The touch screen is working fine. Note: some times in past unit would trip circuit breaker. A reset and unit worked fine for months of use. Vent is clear. Any direction would help. Unit is well maintained has served us well since 1993. Would love to bring her back if economically feasible. Joe
splicedude
All door switches test fine with multi meter. Need to see what else I can check. Thanks
