Magnetron cooling fan motor connections
Cicada17
Washington
Unknown
-major brand-
Less than 1 year
A friend gave me several magnetron cooling fans. Some have two terminals and some have three terminals.
Can anyone tell me which terminal the hot line should be connected to?
Is it an issue with the ones with two terminals?
The three terminal ones have two of the thin hairlike wires from the coil connected to one terminal and one thin wire from the coil connected to the other two terminals.
