MAH6500AWW Error Code ND Neptune Washing Machine
Stingerxtv8
Ohio
MAH6500AWW
Intermittent ND only on last cycle
Cleaned drain line
Impeller motor are clean and work other than during last cycle
Error code ND=No drain.
So you'll need to unplug the machine then take the back access panel off and remove the rubber hoses to the drain pump and the drain pump will twist off the washer bottom base, and check for something clogging the drain pump.
WP25001052 Drain Pump Assembly
